CD Player FD6000 error E11 - In-Car Entertainment (Mk3 Mondeo) - TalkFord.com
7 replies to this topic
#1 richard-cranium
richard-cranium
  • 218 posts
  • Vehicle Driven:03 Ghia X Estate
Posted 26 November 2010 - 02:28 PM
CD was showing "no disc" but wouldn't accept one either!
Now when you press CD it shows:
CD ERROR
E11
The manual says "Internal fault see ford dealer"
Anyone have any ideas? Other than see ford dealer!
Cheers
Rich
02 Silver Mondeo Estate LX 2.0l DuraTorq TDDi 115
'53 Deep Rosso Red Mondeo Estate Ghia X 2.0L DuraTorq TDCi 115 Eibach Pro Lowered on 8.5"x18" Bola B7
#2 44ron
44ron
  • 777 posts
  • Vehicle Driven:MK3 Mondeo ST TDCI
  • Name:Aaron
Posted 26 November 2010 - 04:08 PM
CD ERROR
E11
Cheers
Rich
According to ford "SPI bus failure" "check and repair wiring harness" if OK "replace audio unit"
Usually unplugging the stereo and leaving it for a few mins before plugging it back in solves it. Cross your fingers it does!
2007 MK3 Mondeo ST TDCI in Performance Blue
2004 Street KA Luxury in Storm Grey
#3 richard-cranium
richard-cranium
  • 218 posts
Posted 26 November 2010 - 06:07 PM
Would removing fuse 69 & 72 or disconnecting the battery do the same? Cos I wouldn't know what or where the connector is!
#4 44ron
44ron
  • 777 posts
  • Name:Aaron
Posted 27 November 2010 - 10:14 AM
I don't see why disconnecting the battery wouldn't work. You'll need to leave it for a good few mins to make sure it fully discharges though. Remember to reset your one-touch windows after.
#5 DutchKev
DutchKev
    lovin' the V6
  • 575 posts
  • Vehicle Driven:Focus Zetec S
Posted 27 November 2010 - 10:44 AM
and have the code to hand!
You can lead a fool to wisdom - But you can't make him think
Was my post helpful? Don't forget to use the thanks system on the right!
#6 richard-cranium
richard-cranium
  • 218 posts
Posted 27 November 2010 - 11:29 AM
I have the code but what's this about resetting one touch electric windows :unsure:
#7 44ron
44ron
  • 777 posts
  • Name:Aaron
Posted 27 November 2010 - 11:55 AM
Very very simple process see here.
Let us know if disconnecting the battery solves the problem.
#8 richard-cranium
richard-cranium
  • 218 posts
Posted 30 November 2010 - 01:50 PM
Sorted! Cheers lads.
Disconnected the battery (for a terminal cleanup to help cold strating) and after entering the code.... voila!
Tried with the fuses but both need to be out at the same time and they are fidly.
Now to set the windows!
Ta
