Fuel Pump Question - Diesel Engines (Mondeo Mk3) - TalkFord.com
Fuel Pump Question
8 replies to this topic
#1 cf_corpmk3
cf_corpmk3
    MEG Colonel wannabe
  • 356 posts
  • Vehicle Driven:BMW 320D SE 2001
  • Name:Cathal
Posted 18 September 2010 - 05:07 PM
hi,
thinking of changing my cr high pressure fuel pump. i have the part number r9044z100a k9paa 3s7q-9b3950aa . i see a few pumps on ebay that look like mine but have different part numbers the only thing that matches is the k9paa part. all the pump are identical to mine so does anyone know whats the difference between mine and other pump and would other ones work for mine? thanks
2003 Ford Mondeo TDCI LX 115bhp Hatchback.. NOW SOLD!!!
Mods:
Full engine rebuild
EATC unit fitted
Clear Indicator Lenses
Chrome Bootlid trim
#2 cf_corpmk3
cf_corpmk3
    MEG Colonel wannabe
  • 356 posts
  • Name:Cathal
Posted 20 September 2010 - 04:52 PM
can anyone confirm that tdci injector pumps dont need to be recoded to the ecu unlike tddi's? im sure the main dealer mechanic said that if i changed the tdci pump i wouldnt need to code/program it to the ecu for the immobiliser as that was only for tddi's. anyone change a tdci pump and got it working fine with no programming?
Mods:
Full engine rebuild
EATC unit fitted
Chrome Bootlid trim
#3 totalguy
totalguy
    TDDI Buff
  • 37060 posts
  • Vehicle Driven:mondeo tddi
Posted 20 September 2010 - 05:03 PM
going back to my old td i had a reconditioned pump. the end numbers were different but the supplier assured me it would fit and work so i can only assume that the numbers are revision numbers and perhaps have slight changes inside. i remember also that being a reconditioned unit the electronic system was blank and it coded itself when it was put on the car.
#4 Mabok01
Mabok01
  • 3051 posts
  • Vehicle Driven:Mondeo TDCI 140 2008
  • Name:Michael
Posted 20 September 2010 - 05:29 PM
The TDCI pump doesn't need coded as it is mechanical. I had mines changed a month ago and it wasn't coded in to the car.
2004 Hatchback 130 TDCI Inkblue 564.000 Miles. (Retired)
2008 Hatchback 140 TDCI Sea Grey 136.000 Titanium
Genuine MK3 Ford Mondeo TDCI fuel pump sprocket locking tool and pump mounting bolt tool for rent. Refundable deposit by Paypal required.
#5 markderby
markderby
    Derby Meets Organiser
  • 3834 posts
  • Vehicle Driven:Modifide Fords
  • Name:Mark
Posted 20 September 2010 - 05:42 PM
Nope no code for pump on TDCI only injectors
Had the most powerfull Mondeo Mk3 Ghia X TDCI in the uk now in Mondeo Heaven
Got Mondeo Mk3 TDCI-ST Estate
Got Mondeo Mk4.5 Titanium X Sport Estate
Got Mondeo Mk4 Titanuim X Sport 2.5T Hatch
Got Focus ST225 Hatch Very Modifide
#6 cf_corpmk3
cf_corpmk3
    MEG Colonel wannabe
  • 356 posts
  • Name:Cathal
Posted 20 September 2010 - 07:49 PM
thanks for your responses mark and totalguy. my pump has the part number 3s7q-9b395-aa and i saw one that fits mine with the part numbers 3s7q-9b395-aa, 2S7Q-9B395-AB & 5S7Q-9B395-AA but thats 200gbp with no p&p. the one im looking at for 149gbp posted had the part number 3s7q-9b395-ab, i wonder will it do.
Mods:
Full engine rebuild
EATC unit fitted
Chrome Bootlid trim
#7 totalguy
totalguy
    TDDI Buff
  • 37060 posts
Posted 20 September 2010 - 08:30 PM
i think the 2s7q is to do with the age similar to part numbers for a gem the early gems started with something like 1s7t then you had 2s7t then 3s7t the patern seems to be the same with fuel pump numbers you got there. the 2 numbered one will be mid facelift and the number 3 one will be final facelift.
#8 cf_corpmk3
cf_corpmk3
    MEG Colonel wannabe
  • 356 posts
  • Name:Cathal
Posted 20 September 2010 - 10:48 PM
that makes sense, in the haynes manual it says when the pump fails and eats itself up to fit a later pump with revised insides.
Mods:
Full engine rebuild
EATC unit fitted
Chrome Bootlid trim
#9 cf_corpmk3
cf_corpmk3
    MEG Colonel wannabe
  • 356 posts
  • Name:Cathal
there also seems to be 5s7q
Mods:
Full engine rebuild
EATC unit fitted
Chrome Bootlid trim
